Electric Avenue is Bright, Finishing the ABM Electrics |
EdwardBlume |
Jun 13 2015, 01:40 AM
914 Wizard Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California |
I tested the battery tonight and its putting out a charge. The ABM from what I can tell, has a new engine harness, MSD, JWest fuse panel, a blasted interior, H4s with relays, and a newerish stock board.
With nothing "on", hooking up the battery seems to "arc" the front headlight motors, or something up front. Transmission ground is on, battery (-) is ground, front turn signal grounds are attached. Nothing at the ignition, although with light switch "on" no "arc" but no light. Ignition switch seems loose. Wiper handle is very loose. I bought a color diagram, but I'm color blind. Is there a method to trace electricity step by step from the battery out through the harness, into the dash, and out to the lights? I need to get this ABM on the road! |
walterolin |
Jul 14 2015, 02:48 AM
Senior Member Group: Members Posts: 685 Joined: 30-November 11 From: Louisville, Ky Member No.: 13,838 Region Association: South East States |
Color laminated one is easier to follow, but be aware it has some missing elements. For example the internals of the door switches are not drawn. You will need the Haynes schematics to use together with the color version.
Lo-Fi Version | Time is now: 6th June 2024 - 11:07 PM |
