Front Sway Bar Tabs, Why do I have them? |
914bub |
Jul 15 2015, 06:34 PM
Member Group: Members Posts: 433 Joined: 16-August 13 From: Modesto CA. Member No.: 16,260 Region Association: None |
So yesterday I was under my car working on my exhaust when I looked forward and saw this:
I am going to add a sway bar so I was thrilled to find out I already had them but I'm wondering why I do? The car is a 72 and there's no evidence of damage in the past that would have made replacing both lower control arms necessary. It also does not have holes as if it had a sway bar and somebody removed it.Tabs are factory welded. Anybody else run into this? (IMG:style_emoticons/default/confused24.gif) Not sure why the pic is upside down but you get the idea. |
Dave_Darling |
Jul 15 2015, 10:33 PM
Probably easier to just make more than you need with tabs than to figure out the exact number and make only those.
--DD |
914bub |
Jul 16 2015, 01:14 PM
Probably easier to just make more than you need with tabs than to figure out the exact number and make only those. --DD Dave I hadn't considered the fact that you might have been able to order a sway bar as an option. I knew LE's had them but I thought those were the only cars that came with a sway bar as standard equipment. Did 6's have them? Did "later" cars have them standard? If they were optional for other years any idea how much they cost? |
Lo-Fi Version | Time is now: 10th June 2024 - 07:21 PM |
