> plugging air ports on 75 heads, I promise I did run a search?
brant
post Sep 13 2004, 09:27 AM
I know this has been covered repeatedly..
I guess I'm not good at searching...
1) I'm looking for btdt ideas on plugging the air ports on the 75 2.0 motor...
2) also would love to know if I need to readjust the mixture or do anything to the FI after I plug these.
thanks in advance
brant
nebreitling
post Sep 13 2004, 11:16 AM
Member Emeritus
i found caps at the local ace harware. works fine.
brant   plugging air ports on 75 heads   Sep 13 2004, 09:27 AM
!   You can solder them up...or use brass caps availab...   Sep 13 2004, 09:30 AM
Cap'n Krusty   10x1 mm isn't exactly hardware store stuff. U...   Sep 13 2004, 09:40 AM
brant   Do I need to worry about the mixture after I plug ...   Sep 13 2004, 09:49 AM
Rhodes71/914   On my '75 2.0L they are brazed closed. Don...   Sep 13 2004, 10:35 AM
nebreitling   i found caps at the local ace harware. works fine...   Sep 13 2004, 11:16 AM
brant   Nathan, did you need to adjust mixture afterward...   Sep 13 2004, 11:18 AM
lapuwali   No, as the air is pumped into the exhaust stream. ...   Sep 13 2004, 11:41 AM
maf914   I think the air nozzles delivered air to the exhau...   Sep 13 2004, 11:44 AM
nebreitling   nah, you shouldn't need to adjust the mixture....   Sep 13 2004, 11:46 AM
- Lo-Fi Version Time is now: 26th November 2026 - 05:07 AM
