Electric Avenue is Bright, Finishing the ABM Electrics |
EdwardBlume |
Jun 13 2015, 01:40 AM
I tested the battery tonight and its putting out a charge. The ABM from what I can tell, has a new engine harness, MSD, JWest fuse panel, a blasted interior, H4s with relays, and a newerish stock board.
With nothing "on", hooking up the battery seems to "arc" the front headlight motors, or something up front. Transmission ground is on, battery (-) is ground, front turn signal grounds are attached. Nothing at the ignition, although with light switch "on" no "arc" but no light. Ignition switch seems loose. Wiper handle is very loose. I bought a color diagram, but I'm color blind. Is there a method to trace electricity step by step from the battery out through the harness, into the dash, and out to the lights? I need to get this ABM on the road! |
EdwardBlume |
Jul 22 2015, 11:16 AM
Are these two wires the radio? What gauge wire is speaker wire?
Attached thumbnail(s) |
JeffBowlsby |
Jul 22 2015, 10:59 PM
914 Wiring Harnesses Group: Members Posts: 8,524 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
EdwardBlume |
Jul 22 2015, 11:08 PM
Lo-Fi Version | Time is now: 1st June 2024 - 04:39 AM |
