Oil cooler, Installing |
cpavlenko |
Jul 23 2015, 09:58 PM
Member Group: Members Posts: 489 Joined: 19-April 12 From: North Arizona Member No.: 14,400 Region Association: Southwest Region |
Hi all, well, I'm going to put a oil cooler in the stock 1.7. I'm going with a 12"×9"×4" deep fan cooled oil cooler. Going to put it on the passenger side by the trans. I'm doing this cause the 914 has been running hot in the summer time. Been running at 230 to 240 after a good ride in this heat, around 98 degrees. Should this help. My stock cooler is in good shape and clean. Been freshly tuned also. I'm hoping it'll bring down the temps. Timing is is correct and fuel pressure is good. Engine is a stock 1.7 FI. Sooooo, what u all think about this.
Elliot Cannon |
Jul 24 2015, 12:18 AM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
You might want to determine if it is truly running at 230-240 before investing in an external oil cooler. You need a second opinion. Try a different gage-sender than what you have. Or try a dipstick gage. Also check that the thermostat and cooling flaps are operating freely and the stock oil cooler is free of any debris. Exhaust all possibilities before spending money on something you might not need.
rfinegan |
Jul 24 2015, 04:57 AM
Senior Member Group: Members Posts: 973 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
You might want to determine if it is truly running at 230-240 before investing in an external oil cooler. You need a second opinion. Try a different gage-sender than what you have. Or try a dipstick gage. Also check that the thermostat and cooling flaps are operating freely and the stock oil cooler is free of any debris. Exhaust all possibilities before spending money on something you might not need. (IMG:style_emoticons/default/agree.gif) I did a quick test as above with a Multi meter and themo probe down the dip stick. I had 2 issues of concern with my recent motor swap w/taco and sensor (Unkown sensor) 1) initial key on was not at zero or lost setting needle moved 1-2 mm 2) hot gage reads 240-250 Right of P (TEMP) Hot NC day 98 f and I drive my car pretty aggressively most of the time... on a hot engine the thermo probe of my FLUKE meter reads 203f t o 208 f depending how deep in the dip stick hole or oil level (I use the hottest ) I think a calibration is in order but Im glad I did not check the temp before trying to cool it off more. PO had remote cooler...im thinking it was not needed -Robert |
Lo-Fi Version | Time is now: 4th June 2024 - 06:09 AM |
