QUOTE(Elliot Cannon @ Jul 23 2015, 10:18 PM)
You might want to determine if it is truly running at 230-240 before investing in an external oil cooler. You need a second opinion. Try a different gage-sender than what you have. Or try a dipstick gage. Also check that the thermostat and cooling flaps are operating freely and the stock oil cooler is free of any debris. Exhaust all possibilities before spending money on something you might not need.
I did a quick test as above with a Multi meter and themo probe down the dip stick. I had 2 issues of concern with my recent motor swap w/taco and sensor (Unkown sensor)
1) initial key on was not at zero or lost setting needle moved 1-2 mm
2) hot gage reads 240-250 Right of P (TEMP)
Hot NC day 98 f and I drive my car pretty aggressively most of the time...
on a hot engine the thermo probe of my FLUKE meter reads 203f t o 208 f depending how deep in the dip stick hole or oil level (I use the hottest )
I think a calibration is in order but Im glad I did not check the temp before trying to cool it off more. PO had remote cooler...im thinking it was not needed
-Robert
