Ben's 914 TURBO Official World Premier, 'cuz it didn't blowd up. |
airsix |
Sep 13 2004, 01:04 AM
I have bees in my epiglotis Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 |
Ok, so it isn't as cool as Chapman's 914-6 Turbo 3.0, but it's a turbo 914 all the same. Ladys and Gentlemen, at about 10:00 PST I got boost and there was much rejoicing. I took the car out, filled it with premium, tuned it with the laptop a little to make sure it got plenty of fuel under boost, and the mission was a sucess. Boost starts to come on at ~2,700rpm and is going full-steam by 3,500rpm.
I stand (ok, sit) here before you my brothers to declare that yes indeed, you can turbo a 914. (IMG:style_emoticons/default/clap56.gif) Details: Engine: '73 1.7, stock internals EFI ECU: Perfect Power MIC3 (Cost ~$500 to get on the car and running 3 years ago) Misc EFI stuff: Subaru 1.8T injectors, Holly throttle body off a 3.0 Chrysler, BMW 5xx fuel pump, foam motorcycle aircleaner (temporary) Turbo: IHI off 1.8L Subaru (including wastegate) Misc Turbo stuff: Bosch blow-off valve (for a Saab I think). Cheap. Plastic. Works great. Total cost to add turbo: $175 (EFI was already on the car. Use Megasquirt+turbo and you can do this for <$400 easy) I tried to modify my fuel pressure regulator with a boost-reference port like the in the dune-buggy.com article but I broke off a wire guage drill bit about 1.5" deep into the bolt. Dang. Only had about a quarter-inch to go too. So I just bolted it back on the car and set the fuel pressure at the 30psi I have the ECU turned for. I tried to crank up the injector pulse width under boost to compensate, but they hit 100% duty cycle at 5,000rpm because at that point they only have 20psi effective pressure (because there's 10lb of boost by that point). So I'm keeping it under 5k rpm until I get a rising-rate pressure regulator. The wideband O2 says mixtures are just fine below that point. I estimate I'm getting 110hp (That's not a WAG. I really did the math) which doesn't sound like much but is sure better than the 80hp I had before. I would still like to add an intercooler which could put it in the neighborhood of 130hp without getting too boost-happy. Even as it is now I would say it's 100% more fun to drive. I'm really happy about it. I'll get the pressure regulator issue squared away so I can run it up to 6k and I think it'll keep me happy for quite a while. Rick said "This thread is worthless without pictures" so here's the best I could do. If you missed the earlier thread I'll throw in one of the earlier pics too. I tried to make a video but all you hear is wind noice and the blow-off valve between shifts. |
airsix |
Sep 13 2004, 02:21 PM
You guys are great. Thanks for all the comments.
Header wrap: That's exactly what my engineer Dad said. I said, "yeah, but the pipes are still long" and he reminded me that the pressure response between the head and the turbo is speed-of-sound, so keeping the heat in is really the only issue. I'm not worried about header-wrap rust. I don't drive in the rain, and being a turbo these pipes will rust from the inside out before header-wrap rust is ever an issue. (Dad asked why I didn't do the whole thing in stainless and I said "Because you aren't paying for it".) Thanks for the west-side invites, guys. I cringe though at the thought of letting you look closely. he he. I plan to weld on the SC flares and paint the car this winter/spring. If I do that and tidy up some wiring ugliness maybe I will bring it over if there is a gathering next summer. -Ben M. ps - Wouldn't you know. It was raining cats and dogs this morning. Had to drive the pickup. First rain in a month or more. I was so pumped to drive the 914 today too. (IMG:style_emoticons/default/sad.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 06:49 AM |
