Oil cooler, Installing |
cpavlenko |
Jul 23 2015, 09:58 PM
Member Group: Members Posts: 489 Joined: 19-April 12 From: North Arizona Member No.: 14,400 Region Association: Southwest Region |
Hi all, well, I'm going to put a oil cooler in the stock 1.7. I'm going with a 12"×9"×4" deep fan cooled oil cooler. Going to put it on the passenger side by the trans. I'm doing this cause the 914 has been running hot in the summer time. Been running at 230 to 240 after a good ride in this heat, around 98 degrees. Should this help. My stock cooler is in good shape and clean. Been freshly tuned also. I'm hoping it'll bring down the temps. Timing is is correct and fuel pressure is good. Engine is a stock 1.7 FI. Sooooo, what u all think about this.
campbellcj |
Jul 24 2015, 10:09 PM
I can't Re Member Group: Members Posts: 4,547 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
FWIW on a previous 914 I did the small rear-mounted cooler setup the OP mentioned, and while it probably did help a little, it was far from optimal especially in our hot summers and/or track use. This was on a stock D-Jet 2.0 using a Mocal sandwich thermostat.
If you drive in challenging conditions now or might in the future, I suggest seriously considering a front cooler or some other lashup. My current car has a ginormous front cooler because I wanted to do it once then never think about cooling again. |
Lo-Fi Version | Time is now: 29th May 2024 - 03:08 AM |
