Pushrod Tube seals, viton seals |
Alphaogre |
Jul 28 2015, 11:51 AM
Member Group: Members Posts: 460 Joined: 28-May 12 From: San Diego Member No.: 14,487 Region Association: Southern California |
Has anyone used these viton seals before on the pushrod tubes and valve covers? I would be curious if they would help with the leaking or not?
http://www.autoatlanta.com/Porsche-914-Vit...l-Kit-srch.html Pushrod Tube Seal Kit Who wants to constantly perform the dirty, greasy pushrod tube replacement procedure when these space age viton seals eliminate the problem for years! rated at 450. Degrees, if installed properly you should never have to replace the seals again! Kit comes complete with precise instructions and valve cover gaskets. Everything you need except hand cleaner! Consists of: 8 b021 109 345 a; 2 r021 101 481; 1 rtc 1022 make sure that you readjust the valves and check the valve adjuster lugs for damage. Kit consists of: 8 - b021109349b - pushrod tube seal, large - normally $20.00 8 - b021109345a - pushrod tube seal viton - normally $8.00 2 - r021101481 - valve cover gasket - normally $2.40 1 - btc1022...(choose a part on the right to read more) |
Dave_Darling |
Jul 28 2015, 02:04 PM
Cork gaskets, viton o-rings. If you have an early 1.7 car, make sure to check the bore in the cylinder head. Some early ones are smaller.
You can generally speaking get the parts elsewhere for less than AA charges. (And most places have better customer service IMHO.) This forum is a much better resource than "Dr. George's" instruction set, too. The short version of the instructions: Pull the tubes halfway out of the head to replace the seals. No need to pull them out to the point where they run into the suspension console. --DD |
Lo-Fi Version | Time is now: 10th June 2024 - 08:36 PM |
