Electric Avenue is Bright, Finishing the ABM Electrics |
EdwardBlume |
Jun 13 2015, 01:40 AM
914 Wizard Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California |
I tested the battery tonight and its putting out a charge. The ABM from what I can tell, has a new engine harness, MSD, JWest fuse panel, a blasted interior, H4s with relays, and a newerish stock board.
With nothing "on", hooking up the battery seems to "arc" the front headlight motors, or something up front. Transmission ground is on, battery (-) is ground, front turn signal grounds are attached. Nothing at the ignition, although with light switch "on" no "arc" but no light. Ignition switch seems loose. Wiper handle is very loose. I bought a color diagram, but I'm color blind. Is there a method to trace electricity step by step from the battery out through the harness, into the dash, and out to the lights? I need to get this ABM on the road! |
EdwardBlume |
Jul 29 2015, 12:12 AM
I think I'm getting closer to the issue. With battery on, the headlights are live. Headlight switch off, still live.
Ignition switch which should be live is completely without power. In fact, there's two wires just dangling there. Best I can figure, one is where the real live should go, the other should be switched back to the lights or seats or something. JWest fuse box looks good. Headlight switch is out but there's a ton of wires to it. What do you think? Pict one are the two stray wires off the ignition switch. One for sure is power. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 7th June 2024 - 07:57 AM |
