Electric Avenue is Bright, Finishing the ABM Electrics |
EdwardBlume |
Jun 13 2015, 01:40 AM
914 Wizard Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California |
I tested the battery tonight and its putting out a charge. The ABM from what I can tell, has a new engine harness, MSD, JWest fuse panel, a blasted interior, H4s with relays, and a newerish stock board.
With nothing "on", hooking up the battery seems to "arc" the front headlight motors, or something up front. Transmission ground is on, battery (-) is ground, front turn signal grounds are attached. Nothing at the ignition, although with light switch "on" no "arc" but no light. Ignition switch seems loose. Wiper handle is very loose. I bought a color diagram, but I'm color blind. Is there a method to trace electricity step by step from the battery out through the harness, into the dash, and out to the lights? I need to get this ABM on the road! |
EdwardBlume |
Jul 29 2015, 10:39 PM
I adjusted the headlights so they are down at lights off. The relays or motors still click when you connect the battery.
Pulling the light switch on to park, the 4 corners lit up, but pulling the headlights on doesn't lift the lights or light the H4s. Pulling the hazard switch lit up the dash but no flashing. Turn signal does not work. Progress. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 1st June 2024 - 07:06 AM |
