| falcor75 |
Aug 3 2015, 06:12 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia
I have got a wierd issue with my foglights. I followed this: http://members.rennlist.com/demick/fogrewire.html procedure to get my foglights to act as DRL's with the ignition on. (option 1b)
With ignition on and the fog light switch pulled out the switch lights up and I get 12v on the wires to the foglights, so far all is well. But as soon as I connect a bulb to either of the wires the voltage drops to 0 volts. (IMG:style_emoticons/default/blink.gif) I'm kinda stumped to what's going on.... |
| Larmo63 |
Aug 3 2015, 12:32 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,267 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
The JWest wiring harness that is available on eBay is a good solution to the weird stock fog light arrangement on a 914. It makes the fog light switch operate totally independent of the headlight switch. I like that option because I can also flash my fogs with the high beam switch.
Much better. |
| Porschef |
Aug 3 2015, 06:14 PM
How you doin' ![]() ![]() ![]() ![]() Group: Members Posts: 2,180 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States
The JWest wiring harness that is available on eBay is a good solution to the weird stock fog light arrangement on a 914. It makes the fog light switch operate totally independent of the headlight switch. I like that option because I can also flash my fogs with the high beam switch. Much better. (IMG:style_emoticons/default/agree.gif) It's so simple to install, your fogs become intuitively usable as flashers, and should you use them at night along with the headlights, they won't go out when the brights are on, unless you turn off the switch. A very nice upgrade. |
falcor75 Wierd fog light issue.. Aug 3 2015, 06:12 AM
Spoke Which one of the conversions did you do? Does the ... Aug 3 2015, 11:46 AM
falcor75 I've never been so happy about a broken relay.... Aug 3 2015, 12:46 PM
rhodyguy Nice! Hassle averted. Aug 3 2015, 05:22 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:18 PM |
