Throttle set-up, cable length and bellcrank pivot bracket |
porschetub |
Aug 3 2015, 01:39 AM
Advanced Member Group: Members Posts: 4,703 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Getting closer to fitting the "6" and would like to know the differance in length of the stock 4 cyl throttle cable and the one for the 6 cyl,research indicates there is a differance in length.
Also has anyone got or can link me to a drawing of the throttle cable retainer and bellcrank pivot ,my g/box is a 4 cyl one and I don't have the luxury of an intermediate pivot,thanks in advance. |
Dave_Darling |
Aug 3 2015, 09:14 PM
IIRC, Rich's bellcrank requires you to use the stock -6 cable. I think the -6 cable is shorter than the -4 one, BTW. Pelican used to sell a bellcrank setup that bolted on (no drilling and tapping the intermediate plate like the stock -6 setup) and used a -4 cable. Not sure if they still do; Bruce Stone or Glenn Sager would probably know.
--DD |
porschetub |
Aug 4 2015, 12:49 AM
IIRC, Rich's bellcrank requires you to use the stock -6 cable. I think the -6 cable is shorter than the -4 one, BTW. Pelican used to sell a bellcrank setup that bolted on (no drilling and tapping the intermediate plate like the stock -6 setup) and used a -4 cable. Not sure if they still do; Bruce Stone or Glenn Sager would probably know. --DD Thanks Dave have a order pending so may ask,only need the bracket...maybe thats an issue?. |
Lo-Fi Version | Time is now: 1st June 2024 - 02:17 AM |
