> Installing Intermittent Wipers, Just 4 wires, What could go Wrong?
914Sixer
post Aug 2 2015, 04:26 PM
My only project for today was to install the intermittent wiper harness and relay. Yesterday I had reworked the wiper rack and checked the motor out on the bench. I had a intermittent wiper harness still attached to a complete 74 harness, so no problem. Being an old telephone man, I drew a diagram of how the wires were attached to the harness for the wiper. I noticed one of the wires (brown/black)had been cut off coming out of the harness plug. I knew it was important because one of the relay spades plugged into it. I dug around in the old harness but I did not find the other end. HUMMM?
So I took the harness over to my 75 and wired up the connections from the diagram. I looked at the harness and found the brown/black wire tied back and the spade covered. Clean off the cover and plugged it into the harness. Time for a test.
Turned the wipers on and everything worked fine, or so I though. Turned the switch off and the intermittent kept on working with the ignition switch off. (IMG:style_emoticons/default/headbang.gif)
Backed up and checked all the wiring and everything was ok according to the diagram. HUMMM? Since I had changed out the steering column last week, I looked under at the connections there too. Everything looked good too, then the light came on, did I put the 5 pin wiper switch in the column? NO!! (IMG:style_emoticons/default/hissyfit.gif) Started all over on the column and redid it with the correct 5 pin switch. Plugged everything up and checked, finally, or so I thought.
The wiper motor would stop when you turned off the switch, then move a 1/4 round down by itself. Pulled out the 2nd wiper motor and bench tested it. Stuck it in the rack and found it had no high speed. Finally, the 3rd wiper motor worked correctly. Got ready to install the assembly and the rubber mount broke off!
Oh Well. It seemed like a good place to stop for the day.
steuspeed
post Aug 3 2015, 04:20 PM
Get a VW MK2 programmable relay #99. It allows you to adjust the intermittent timing using the stalk control. All the VW guys get these. It's a plug and play upgrade for the intermittent wiper relay.
http://www.ebay.com/itm/VW-Audi-Programabl...eac&vxp=mtr
porschetub
post Aug 4 2015, 04:19 AM
QUOTE(steuspeed @ Aug 4 2015, 10:20 AM) *
Not sure, I think it is only this way in the car it was designed for,the 914 has no wiper lever to control this fuction as the Golf has...might be wrong but a stand-alone variable switch would do the job?
914Sixer   Installing Intermittent Wipers   Aug 2 2015, 04:26 PM
porschetub   My only project for today was to install the inte...   Aug 2 2015, 09:29 PM
porschetub   My only project for today was to install the int...   Aug 3 2015, 06:35 PM
914Sixer   I had the plug harness from another car. You can ...   Aug 3 2015, 05:24 AM
Mark Henry   Is there a wire schematic (link?) and what is the ...   Aug 3 2015, 07:14 AM
steuspeed   Get a VW MK2 programmable relay #99. It allows you...   Aug 3 2015, 04:20 PM
worn   Get a VW MK2 programmable relay #99. It allows yo...   Aug 3 2015, 06:06 PM
jim_hoyland   Get a VW MK2 programmable relay #99. It allows yo...   Aug 3 2015, 06:52 PM
worn   [quote name='steuspeed' post='2218268' date='Aug ...   Aug 3 2015, 07:55 PM
steuspeed   [quote name='steuspeed' post='2218268' date='Aug...   Aug 3 2015, 09:07 PM
porschetub   Get a VW MK2 programmable relay #99. It allows yo...   Aug 4 2015, 04:19 AM
914Sixer   Thanks for the relay tip. Going to get one for th...   Aug 3 2015, 04:58 PM
914Sixer   Well I ordered a relay to test with. Should be he...   Aug 3 2015, 07:11 PM
worn   My only project for today was to install the inte...   Aug 3 2015, 07:59 PM
914Sixer   Further relay research. 1HM 955 531 and 531C are ...   Aug 3 2015, 08:19 PM
Jeff Bowlsby   More relays ID'd in here:   Aug 3 2015, 09:01 PM
Valy   Th VW 99 relay it's not a plug and play but ju...   Aug 3 2015, 11:00 PM
914Sixer   Here is the wiper switch that you need if you want...   Aug 4 2015, 09:01 PM
Valy   Here is the wiper switch that you need if you wan...   Aug 5 2015, 10:31 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 04:45 PM
