> LS4 to Boxster S Transaxle conversion, Axles
timothy_nd28
post Aug 7 2015, 01:59 PM
I'm getting ready to pull the trigger with Renegade Hybrids for some random parts for my conversion.
The price for the LS engine bar, rear boxster cradle mount, cooling kit are reasonable prices. However, they want 1200 dollars for 2 axles that bolt up to the boxster transmission to 911 hubs (which I don't have either)
These 911 hubs are somewhat expensive too! Renegade is putting my order together soon, and will call me with their paypal info. Should I go ahead and use their product for the axles, or is there a cheaper route?
Thanks
1stworks
post Aug 8 2015, 07:45 AM
I bought these conversion pieces for axles. They bolt to my 4 bolt stub axles then got to 100 mm cv outboard and 108mm inboard.
Pretty cheep.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1315.photobucket.com-15718-1439041547.1.jpg)
Here's where I'm at (IMG:style_emoticons/default/biggrin.gif)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1315.photobucket.com-15718-1439041547.2.jpg)
timothy_nd28
post Aug 8 2015, 11:03 AM
[/quote]
Thanks for the advise, this is a great option. The tub I bought came with 914 hubs that were already drilled for 5 lugs. At this point, not really sure which route to go, but I do know that I will scratch off the axle kit from the order list at Renegade.
That transmission mount looks pretty cool, is that what I should expect from Renegade, never seen a picture of it. That adapter plate looks pretty thick, was that made from Kennedy Adapters? Kennedy pretty much told me to screw off once they knew I was trying to mate a LS4 to a Boxster 6 speed. The LS4 has no provisions for a starter, same holds true for the Boxster transaxle. After some intense searching, I found a company that has mated these two before and only charges 1500 for the adapter plate, flywheel, pressure plate, clutch and starter. The LS4 seems pretty popular with the Fiero crowd, and has been even installed in a MGB! I also like the idea that this engine can disable 4 cylinders at freeway speeds to conserve fuel. This will be a fun project! (IMG:style_emoticons/default/driving.gif)
timothy_nd28   LS4 to Boxster S Transaxle conversion   Aug 7 2015, 01:59 PM
mepstein   I would talk to sway away. There custom axles are ...   Aug 7 2015, 04:02 PM
Mike Bellis   Don't pay $1200 for axles. Call these guy...   Aug 7 2015, 05:11 PM
madmax914   You Might check with Kent Porter at Precision Chas...   Aug 7 2015, 05:14 PM
timothy_nd28   I was hoping you would chime in, thank you :worsh...   Aug 7 2015, 05:15 PM
1stworks   I bought these conversion pieces for axles. They b...   Aug 8 2015, 07:45 AM
timothy_nd28   Here's where I'm at :D http://www.914wo...   Aug 8 2015, 11:03 AM
Stacks914   Man that looks really good! you go with KEP a...   Aug 8 2015, 12:41 PM
1stworks   Here's where I'm at :D [img]http://www...   Aug 8 2015, 06:49 PM
1stworks   Just a FYI check everything renagade sends you for...   Aug 8 2015, 08:17 AM
matthepcat   As an alternative to new axles you might be able t...   Aug 8 2015, 08:23 AM
Mike Bellis   As an alternative to new axles you might be able ...   Aug 8 2015, 08:54 AM
Mike Bellis   I forgot to mention that Patrick Motorsports sells...   Aug 8 2015, 08:52 AM
MSHax   Here's where I'm at :D [img]http://ww...   Aug 8 2015, 12:58 PM
timothy_nd28   Man, that's pretty! :drooley:   Aug 8 2015, 07:01 PM
1stworks   Sorry for lighting up your post. http://www.914wo...   Aug 8 2015, 07:01 PM
timothy_nd28   Please do   Aug 8 2015, 07:04 PM
1stworks   :D http://www.914world.com/bbs2/uploads_offsite/...   Aug 8 2015, 07:07 PM
mepstein   :D http://www.914world.com/bbs2/uploads_offsite...   Aug 9 2015, 08:41 AM
1stworks   [quote name='1stworks' post='2220804' date='Aug 8...   Aug 9 2015, 09:25 AM
mepstein   [quote name='mepstein' post='2220972' date='Aug 9...   Aug 9 2015, 09:49 AM
BIGKAT_83   Don't pay $1200 for axles. Call these gu...   Aug 8 2015, 07:56 PM
Stacks914   Thanks for the pics! You have no idea how I h...   Aug 8 2015, 09:22 PM
1stworks   Thanks for the pics! You have no idea how I ...   Aug 9 2015, 07:47 AM
timothy_nd28   Is the radiator narrow enough to lay down in the t...   Aug 9 2015, 06:46 PM
mepstein   Is the radiator narrow enough to lay down in the ...   Aug 9 2015, 07:21 PM
1stworks   And it's in. http://www.914world.com/bbs2/up...   Aug 11 2015, 07:45 AM
timothy_nd28   How about a pic showing the clearance between the ...   Aug 11 2015, 10:59 AM
1stworks   http://www.914world.com/bbs2/uploads_offsite/i1315...   Aug 11 2015, 11:47 AM
1stworks   Didn't remove front or sides of engine tins. M...   Aug 11 2015, 11:51 AM
timothy_nd28   Such a nice fit :Qarl: I can't wait for my...   Aug 11 2015, 12:42 PM
1stworks   Make sure you get all the upgraded mounts,engine a...   Aug 12 2015, 09:45 AM
Joemo5   Make sure you get all the upgraded mounts,engine ...   Jun 10 2018, 01:13 PM
1stworks   Ouch looking for 4 bolt solution. http://www.914...   Aug 12 2015, 11:01 AM
timothy_nd28   Looks great, loving that transaxle mount! Did...   Aug 12 2015, 12:03 PM
1stworks   Looks great, loving that transaxle mount! Di...   Aug 13 2015, 06:28 AM
1stworks   Good progress on axles today.Found shop in town t...   Aug 13 2015, 08:27 PM
timothy_nd28   Which transaxle do you have?   Aug 13 2015, 08:39 PM
1stworks   2002 boxster S 6 speed   Aug 13 2015, 09:20 PM
Derek 357i   Can someone pm me the name of the company that doe...   Aug 16 2017, 06:59 AM
timothy_nd28   http://www.kitcarchassis.com/contact.php   Aug 16 2017, 12:25 PM
Derek 357i   http://www.kitcarchassis.com/contact.php Thanks...   Aug 17 2017, 08:58 AM
dakotaewing   Anybody have alternatives to Renegades Boxter s Mo...   Jun 9 2018, 09:17 AM
Mike Bellis   Anybody have alternatives to Renegades Boxter s M...   Jun 9 2018, 05:35 PM
dakotaewing   Anybody have alternatives to Renegades Boxter s ...   Jun 10 2018, 07:12 AM
Cracker   Oops! I just noticed the date of this thread.....   Jun 10 2018, 05:25 AM
mepstein   Oops! I just noticed the date of this thread....   Jun 10 2018, 06:26 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:20 AM
