off topic once again , aftermarket bucket seat for. 2001 ranger regular cab, whats the best and cheapest way to get this done |
thelogo |
Aug 9 2015, 07:02 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
So my ranger bench 60-40 seat is torn to s#it on the drivers side I tried going the stock replacement route but could only find Extended cab seats on Craig's list And from what I understand regularly cab seats and bracket s Are different from extended cab seats and bracket s Can anyone with ranger experience confirm this ???? So I think I'm just gonna go with a procar seat aka scat for about 200$ and use their Ford ranger bracket which is supposed to Bolt right in and seat right in to bracket I'm 6-2 so seat will always be in the all the way back position And something that sits lower then stock would be good I m assumeing seat belts will be retained and not sure about Airbag or seatbelt wire that plugs into bottom of stock seat . Am I going the right direction here or is there a better way . I thought about the whole 're upholstered route but not sure what that cost . Advice please. ! (IMG:style_emoticons/default/pray.gif) |
Chris914n6 |
Aug 9 2015, 10:02 PM
Jackstands are my life. Group: Members Posts: 3,333 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
If the Ranger is like any other truck, the floor mounts are the same, so the buckets n brackets from the same era should bolt in. A Ranger forum would tell you for sure.
$200 should get you most of the bench recovered. Shop around a little. |
thelogo |
Aug 9 2015, 10:29 PM
If the Ranger is like any other truck, the floor mounts are the same, so the buckets n brackets from the same era should bolt in. A Ranger forum would tell you for sure. $200 should get you most of the bench recovered. Shop around a little. Thanks for the reply I looked at forums Here is what I found I may be interpretinng this incorrect but http://www.therangerstation.com/tech_library/Seats.shtml One other word of warning Ranger Standard-cab, Ranger Supercab and Bronco II's all have different floor pan profiles and so use different seat tracks, so if you want to put buckets or a split-bench into a std cab Ranger you must get your seat tracks out of a std cab Ranger. |
Lo-Fi Version | Time is now: 7th June 2024 - 12:04 PM |
