New brake lines, New brake lines |
shandyhaggis |
Aug 12 2015, 08:16 AM
Newbie Group: Members Posts: 49 Joined: 2-February 11 From: UK Member No.: 12,653 Region Association: None |
Hello all
Ive got the stage of my restoration that I have the pleasure of fitting all new shiny brake lines. Ive got some pre-made ones from MittleMotor in Germany and Im just going through the process of figuring out which pipe is used where. Ive got the 914 PET which is useful to locate roughly where pipes run but it doesnt show pipe lengths which would have been useful. Does any one have any pointers on generally fitting new pipes? I cant find any pictures showing how the lines run. Its a long time since I pulled the old ones out and I didnt take any snaps:-( thanks if you can help! Andrew |
Eric_Shea |
Aug 12 2015, 08:00 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Just dig in. In a few minutes, reasonable deduction and the process of elimination will have you sussed.
Long one = center tunnel Two Shepards hooks = rear caliper hardlines Little L = Pressure regulator to center tunnel Medium sized line with a crescent = Front right etc... |
shandyhaggis |
Aug 13 2015, 03:57 AM
Just dig in. In a few minutes, reasonable deduction and the process of elimination will have you sussed. Long one = center tunnel Two Shepards hooks = rear caliper hardlines Little L = Pressure regulator to center tunnel Medium sized line with a crescent = Front right etc... thanks for that. Ive my old pipes I can compare against if I gently unfold them from the ball I made of them when I ripped them off the car (note to self for next time). The new pipes arnt shaped so Ill have to check the lengths aginst he old ones to make sure Ive got the right one. If I mess up I can always by a length or 2 with an couple of tools and make some new ones up. thanks Andrew |
Lo-Fi Version | Time is now: 6th June 2024 - 06:05 PM |
