Turbo charge the Porsche 2.0 ?.. Thoughts? |
Beakster |
Aug 14 2015, 06:35 PM
Member Group: Members Posts: 121 Joined: 13-August 15 From: Calgary,AB Canada Member No.: 19,055 Region Association: None |
I'm been told to KISS IT ... keep it simple stupid ... I'm better off with taking the 4cyl 2.0 and bore it and putting a turbo on it .. or even going to the VW Turbo engs It would just be an easier job to pull the engine beef it up and put it back in then to look at another big project and more big time dough($$$) on putting the Turbo 3.3 eng and 4sp trans in the 914 .. Anyone around that has Turbo the 2.0? could use some help on this one .... Thanks !
tango |
Aug 15 2015, 08:08 AM
Newbie Group: Members Posts: 2 Joined: 7-January 05 From: UK Member No.: 3,417 Region Association: None |
Here is what I did. I wanted no cutting to the shell at all. The turbo on the drivers side infront of the axle. I just reworked it a little more to add a ducted IC rather than water/air IC since that would involve water and pipework etc etc.
I like tuning/tweaking and fab work (and testing out the results) and have my own AC TIG but it could be simplified and done with MIG only. I am running a very mild cam, gives great off idle response until the boost takes over and is also less stress on the valve train. My turbo is a smaller GT28R but seems a great match for street. Cheaper T3/4s will do similar I believe, or a plain non ball bearing GT28. There is no need to go with the equal length curly header. Improving the exh valve flow should help, ditch the Sodium valves. There is also no need for extreme valve springs; keep the valve train light instead if possible. I use MS2 (3 module waiting to be fitted) for control including boost. Be cautious tuning on stock pistons, they wont take much knock but the low STD CR is OK for low boost, add copper head gaskets (gasp!) for more boost. Even 7psi will feel amazing and you wont need an IC for that. |
MSHax |
Aug 15 2015, 08:13 AM
Member Group: Members Posts: 55 Joined: 8-August 15 From: California Bay Area Member No.: 19,039 Region Association: Central California |
Here is what I did. I wanted no cutting to the shell at all. The turbo on the drivers side infront of the axle. I just reworked it a little more to add a ducted IC rather than water/air IC since that would involve water and pipework etc etc. I like tuning/tweaking and fab work (and testing out the results) and have my own AC TIG but it could be simplified and done with MIG only. I am running a very mild cam, gives great off idle response until the boost takes over and is also less stress on the valve train. My turbo is a smaller GT28R but seems a great match for street. Cheaper T3/4s will do similar I believe, or a plain non ball bearing GT28. There is no need to go with the equal length curly header. Improving the exh valve flow should help, ditch the Sodium valves. There is also no need for extreme valve springs; keep the valve train light instead if possible. I use MS2 (3 module waiting to be fitted) for control including boost. Be cautious tuning on stock pistons, they wont take much knock but the low STD CR is OK for low boost, add copper head gaskets (gasp!) for more boost. Even 7psi will feel amazing and you wont need an IC for that. Great Work! Looks amazing! Thanks for posting this, it really helps to visualize how its possible |
Lo-Fi Version | Time is now: 8th June 2024 - 03:54 AM |
