> Need "Machinist"? - Need A Mounting Plate Made, ...to relocate the clutch pulley wheel for a header
7TPorsh
post Aug 16 2015, 01:44 PM
7T Porsh
I have the skills but don't have the tools or the material to do this. I need a steel plate made with three holes in it so i can re-angle the clutch pulley for my header installation.
With the header on, the clutch cable rubs on the header. A custom plate between the clutch pulley housing and the transmission will enable me to rotate the housing slightly so the angle of the cable goes further down and gives some clearence to the header. Cable will be wrapped with fireproof sleeve.
Can anyone out there fabricate this? I will get exact measurements. The plate is small; 3"x 5" tops.
I have seen the other mount made that relocates the pulley horizontal but that will not work for mine.
I anticipate that more than just me may want one of these.
Can anyone out there punch this out?
914forme
post Aug 16 2015, 05:37 PM
I just welded a piece onto the pulley holder piece, easy peasy. Done, and worked great.
7TPorsh
post Aug 16 2015, 09:41 PM
7T Porsh
QUOTE(914forme @ Aug 16 2015, 04:37 PM) *
Can't weld....oh the things I could do if only.....
7TPorsh   Need "Machinist"? - Need A Mounting Plate Made   Aug 16 2015, 01:44 PM
Mueller   steel or aluminum? thru hole or threaded or nuts ...   Aug 16 2015, 02:18 PM
7TPorsh   steel or aluminum? thru hole or threaded or nuts...   Aug 16 2015, 03:27 PM
Harpo   What about Chris's clutch pulley adapter http...   Aug 16 2015, 02:55 PM
7TPorsh   What about Chris's clutch pulley adapter htt...   Aug 16 2015, 03:25 PM
Harpo   Chris has two designs, one horizontal & one ve...   Aug 16 2015, 04:08 PM
7TPorsh   Chris has two designs, one horizontal & one v...   Aug 16 2015, 09:39 PM
Mueller   I just happen to have this .25" thick steel p...   Aug 16 2015, 04:13 PM
7TPorsh   I just happen to have this .25" thick steel ...   Aug 16 2015, 09:43 PM
914forme   I just welded a piece onto the pulley holder piece...   Aug 16 2015, 05:37 PM
7TPorsh   I just welded a piece onto the pulley holder piec...   Aug 16 2015, 09:41 PM
914forme   I just welded a piece onto the pulley holder pie...   Aug 17 2015, 04:40 AM
Marty Yeoman   Looks like a job for a waterjet. I suggest making ...   Aug 16 2015, 10:03 PM
Racer Chris   This is all you need.   Aug 17 2015, 06:48 AM
blackmoon   This is all you need. simplicity at it's b...   Aug 17 2015, 09:32 AM
7TPorsh   This is all you need. simplicity at it's ...   Aug 17 2015, 10:42 AM
7TPorsh   Here are the dimensions for either:   Aug 17 2015, 10:43 AM
Racer Chris   I keep them on the shelf. Every EVO 914 header get...   Aug 17 2015, 10:44 AM
7TPorsh   I keep them on the shelf. Every EVO 914 header ge...   Aug 17 2015, 11:06 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 03:57 PM
