| max72914 |
Aug 16 2015, 04:45 PM
Newbie ![]() Group: Members Posts: 43 Joined: 17-February 15 From: Bellingham, WA Member No.: 18,447 Region Association: Pacific Northwest |
Hi everyone, I ordered a new caliper off ebay, for the front left. I got a call from the mechanic that it doesnt fit, and the bolts at the bottom are farther apart. I talked to the seller, and he said that there is nothing wrong and it should fit fine. The original caliper says vw 42 on it, im guessing its 42mm bore? Whos right, the mechanic, or the seller? Could the brakes be from a different car? Thanks,
Max Attached thumbnail(s) Attached image(s)
| stugray |
Aug 16 2015, 11:01 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
The shiny new caliper looks like a Late caliper. (slightly oddly shaped one)
It has no nuts (casting is threaded) and it has dual bleeders. The rusty caliper is a Early caliper (drivers side?) It has nuts on the fastener and single bleeders. The rotor has to match the caliper (early with early, late with late) or you wont even be able to slide the caliper in place. Either one should bolt onto the mounting tabs if there is no rotor installed. |
max72914 1971 brake caliper issues Aug 16 2015, 04:45 PM
max72914
Hi everyone, I ordered a new caliper off ebay, fo... Aug 16 2015, 04:46 PM
max72914
mepstein Doesn't look like a 914 caliper. Aug 16 2015, 04:52 PM
max72914
The new one... Aug 16 2015, 05:16 PM
era vulgaris Your new caliper looks a lot like the ones I put o... Aug 16 2015, 05:57 PM
max72914
Your new caliper looks a lot like the ones I put ... Aug 16 2015, 07:33 PM
max72914
Your new caliper looks a lot like the ones I put ... Aug 16 2015, 07:34 PM
Spoke
Tip: don't buy parts from ebay
:agree:
... Aug 17 2015, 11:31 AM
max72914 You can PM Eric at Eric_Shea.
And/Or go to his we... Aug 17 2015, 12:38 PM
mgp4591 Paging Mr. Shea, Mr. Eric Shea... you have a call ... Aug 16 2015, 07:06 PM
Dave_Darling First question: Do you have five-lug wheels?
Sec... Aug 17 2015, 09:17 AM
max72914
Se... Aug 17 2015, 12:36 PM
Eric_Shea That's a Chioneese caliper. They're crap.... Aug 18 2015, 08:02 AM
johnhora Max...
I have this pair of cores for the front if ... Aug 18 2015, 10:51 AM
max72914
Max...
I have this pair of cores for the front if... Aug 18 2015, 10:57 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:59 AM |
