| 7TPorsh |
Aug 16 2015, 01:44 PM
7T Porsh ![]() ![]() ![]() ![]() Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California
I have the skills but don't have the tools or the material to do this. I need a steel plate made with three holes in it so i can re-angle the clutch pulley for my header installation.
With the header on, the clutch cable rubs on the header. A custom plate between the clutch pulley housing and the transmission will enable me to rotate the housing slightly so the angle of the cable goes further down and gives some clearence to the header. Cable will be wrapped with fireproof sleeve. Can anyone out there fabricate this? I will get exact measurements. The plate is small; 3"x 5" tops. I have seen the other mount made that relocates the pulley horizontal but that will not work for mine. I anticipate that more than just me may want one of these. Can anyone out there punch this out? ![]() |
| 7TPorsh |
Aug 17 2015, 10:43 AM
Here are the dimensions for either:
7TPorsh Need "Machinist"? - Need A Mounting Plate Made Aug 16 2015, 01:44 PM
Mueller steel or aluminum?
thru hole or threaded or nuts ... Aug 16 2015, 02:18 PM
7TPorsh
steel or aluminum?
thru hole or threaded or nuts... Aug 16 2015, 03:27 PM
Harpo What about Chris's clutch pulley adapter
http... Aug 16 2015, 02:55 PM
7TPorsh
htt... Aug 16 2015, 03:25 PM
Harpo Chris has two designs, one horizontal & one ve... Aug 16 2015, 04:08 PM
7TPorsh
Chris has two designs, one horizontal & one v... Aug 16 2015, 09:39 PM
Mueller I just happen to have this .25" thick steel p... Aug 16 2015, 04:13 PM
7TPorsh
I just happen to have this .25" thick steel ... Aug 16 2015, 09:43 PM
914forme I just welded a piece onto the pulley holder piece... Aug 16 2015, 05:37 PM
7TPorsh
I just welded a piece onto the pulley holder piec... Aug 16 2015, 09:41 PM
914forme
I just welded a piece onto the pulley holder pie... Aug 17 2015, 04:40 AM
Marty Yeoman Looks like a job for a waterjet.
I suggest making ... Aug 16 2015, 10:03 PM
Racer Chris This is all you need.
Aug 17 2015, 06:48 AM
blackmoon
simplicity at it's b... Aug 17 2015, 09:32 AM
7TPorsh
simplicity at it's ... Aug 17 2015, 10:42 AM
Racer Chris I keep them on the shelf. Every EVO 914 header get... Aug 17 2015, 10:44 AM
7TPorsh
I keep them on the shelf. Every EVO 914 header ge... Aug 17 2015, 11:06 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:06 PM |
