Electric Avenue is Bright, Finishing the ABM Electrics |
EdwardBlume |
Jun 13 2015, 01:40 AM
I tested the battery tonight and its putting out a charge. The ABM from what I can tell, has a new engine harness, MSD, JWest fuse panel, a blasted interior, H4s with relays, and a newerish stock board.
With nothing "on", hooking up the battery seems to "arc" the front headlight motors, or something up front. Transmission ground is on, battery (-) is ground, front turn signal grounds are attached. Nothing at the ignition, although with light switch "on" no "arc" but no light. Ignition switch seems loose. Wiper handle is very loose. I bought a color diagram, but I'm color blind. Is there a method to trace electricity step by step from the battery out through the harness, into the dash, and out to the lights? I need to get this ABM on the road! |
EdwardBlume |
Aug 17 2015, 06:45 PM
Does the Saab relay take care of the H4s or are additional wiring needed?
Mike Bellis |
Aug 17 2015, 08:26 PM
Does the Saab relay take care of the H4s or are additional wiring needed? The Saab relay has extra external pins that are joined in the 914 relay. The Saab is also electronic switching and does not rely on the old coil/cam system like the 914. It's also twice as wide but will tuck up nicely under the dash. Here is my thread on this mod for your reading pleasure... http://www.914world.com/bbs2/index.php?sho...lectronic+relay |
Lo-Fi Version | Time is now: 1st June 2024 - 06:22 AM |
