6 cylinder oil scavenge line, With heat exchangers |
'73-914kid |
Aug 18 2015, 04:09 PM
Senior Member Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
Quick question for those of you running heat exchangers and an external oil cooler..
What did you do for the oil scavenge line that come out of the passenger side of the engine case? I have an old pipe that someone welded a -12 AN fitting to, however it was pinched long before I ever came across the engine, and I'm looking for an alternative. Patrick motorsports sells a line than looks exactly like mine for $160 (option 1) My other thought was to run an AN line off the case to my thermostat at the firewall, however I don't know if there is sufficient room for this line to fit with heat exchangers and the heater boxes. So, what have some of you done that are in this situation? I would much rather build a line myself with AN fittings than blow a bunch of cash on a rather simple oil pipe from PMS.. |
'73-914kid |
Aug 19 2015, 07:56 AM
All very good advice from the group. Question though.. Steve, you say the PMS line fits no problem with your heat exchangers, and someone else says it doesn't fit.. I was going to just order the PMS part so I didn't have to worry about welding on a fitting, but now there is some concern..
Can anyone else either confirm or deny that this line works with factory heat exchangers? |
Lo-Fi Version | Time is now: 29th May 2024 - 03:20 AM |
