Finishing A 914-6 GT Conversion Project, Great Start, But The Devil Is In The Details! |
Lucky9146 |
Aug 3 2015, 10:29 PM
Always Wanted A Bigger Go Cart Group: Members Posts: 1,620 Joined: 22-September 14 From: Poway California Member No.: 17,942 Region Association: Southern California |
Bought This car in Nov 2013 and unfortunately it had to sit in my trailer until May of this year to get started on it. The picture is how the car looked the way I got it and how it came out of the trailer. Factory P/N steel flares, nice paint job, a not installed 3.0 close to ready to install, Oh, and an in process conversion. Just some cleaning and put it together and yes a lot of learning/ research. Because (a) I have never owned a 914. (b) never done an engine conversion (built a few). © never picked up where someone left off (you know how its easier to put something back together when you take it apart).
I got the "bug" from a friend who took me up the Ortega Hwy in his 6 conversion and I was hooked. I decided to share my experiences with the "world" and hopefully along the way gain some insight. I have met some great 914 folks so far at swap meets and parts houses and everyone has been quite helpful. I will tell more of the story of what came with the car and what I have done so far as the days go by. Check in once in a while. Attached thumbnail(s) |
Lucky9146 |
Aug 22 2015, 10:07 AM
It is my understanding that from '73 up the vehicles had the wiring harness for the center console regardless of whether the console was installed or not. There was connector just forward of the shifter in the main loom that runs in the center tunnel. It not only provided for the wires from the sender, but power to the gauge lighting and grounds. I this picture shows the connector but it is behind the shifter? The wiring for the PO removed console in my car did not come from here but came from elsewhere.
tp_reading |
Aug 22 2015, 01:36 PM
Member Group: Members Posts: 58 Joined: 4-May 15 From: United Kingdom Member No.: 18,698 Region Association: None |
It is my understanding that from '73 up the vehicles had the wiring harness for the center console regardless of whether the console was installed or not. There was connector just forward of the shifter in the main loom that runs in the center tunnel. It not only provided for the wires from the sender, but power to the gauge lighting and grounds. I this picture shows the connector but it is behind the shifter? The wiring for the PO removed console in my car did not come from here but came from elsewhere. Hi, interested to see from this pic that you have a parking brake lever situated centrally. I have 930 discs on the back, and hence no parking brake. Any info on your set up would be much appreciated. Cheers, Tony |
Lo-Fi Version | Time is now: 7th June 2024 - 05:37 PM |
