Whats the Best way to upgrade a stk 2.0 ?, how to get more PWR with stk parts,.. |
flmont |
Aug 24 2015, 04:51 PM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
Iam trying to upgrade my 2.0 type 4 and the machine shop is a little leary,..of going with bigger valve's for fear of the seats falling out,..so If I keep stk heads,..what are my choices for going for more PWR,..I know larger PC's are planned,.. 96MM,..with larger cam,..using weber carbs,..( ICT 34's is what came off the engine,.) I don't need to use those carbs, if there are better options ,..like 40 or 44's,..can I keep original crank and rods,. I would like to if there still good,..just trying to punch it up as much as I can using close to stk or stk parts,..??? they talked about higher compression ratio's,..??? Thanks Frank
Mblizzard |
Aug 24 2015, 06:18 PM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
I would look into getting a matched kit from someone like the Type 4 Store. They have done all of the homework and can get you a solid kit together that uses most of your stock parts.
That way you get something that is proven to work. I don't think case work is required unless you go bigger than 96 mm on the P/C. |
Lo-Fi Version | Time is now: 8th June 2024 - 07:52 AM |
