Whats the Best way to upgrade a stk 2.0 ?, how to get more PWR with stk parts,.. |
flmont |
Aug 24 2015, 04:51 PM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
Iam trying to upgrade my 2.0 type 4 and the machine shop is a little leary,..of going with bigger valve's for fear of the seats falling out,..so If I keep stk heads,..what are my choices for going for more PWR,..I know larger PC's are planned,.. 96MM,..with larger cam,..using weber carbs,..( ICT 34's is what came off the engine,.) I don't need to use those carbs, if there are better options ,..like 40 or 44's,..can I keep original crank and rods,. I would like to if there still good,..just trying to punch it up as much as I can using close to stk or stk parts,..??? they talked about higher compression ratio's,..??? Thanks Frank
koozy |
Aug 24 2015, 10:56 PM
Senior Member Group: Members Posts: 651 Joined: 21-July 07 Member No.: 7,931 Region Association: None |
71 x 101 which will give you a 2.3 liter. 44mm carbs and you will be a very happy camper. Don't bump the compression too much. That decreases longevity.
Lo-Fi Version | Time is now: 7th June 2024 - 07:54 PM |
