Lost a cylinder, Car is missing bad |
catsltd |
Aug 26 2015, 03:52 PM
Member Group: Members Posts: 181 Joined: 7-June 15 From: Calgary Alberta Member No.: 18,814 Region Association: None |
Been working steadly on fixing my 1974 1.8L.
New injectors,plugs,Petronic point replacemnt.etc. Driving to the store when all of a sudden something happened. Car felt like it had dropped 1 of the cylinders. Car does not rev at all,made it home and parked it. Diid a compression test (cold),110 110 100 90. Not happy with 90 on cylinder 1 but felt at least like motor should still be running. Where do I go next.???? I have a dual vacuum line throttle body,and a single vacum on my for sure non stock distributor that had a 4500 RPm rev limiter. (Distribitor mark for cylinder 1 is 180 degrees out.) Like I said I put on a pertronic 1847 and a petronic blaster coil and 8MM wires. I am thinking its a spark think,but really dont know what to do at this point. I have ordered a Mallory Unilite distribitor(4554101),but wont install it till I figure this out. Hoping for some help from you guys. Thanks Grant. |
Valy |
Aug 26 2015, 08:10 PM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
What do you mean by dizzy 180 over?
Did you check it with a timing light? Don't look at the angle of the dizzy, all that's important to see is if cylinder 1 lights the light in the right spot. What ignition angle you get at 3500 RPM without vacuumatic advance? |
Lo-Fi Version | Time is now: 6th June 2024 - 05:16 PM |
