Lost a cylinder, Car is missing bad |
catsltd |
Aug 26 2015, 03:52 PM
Member Group: Members Posts: 181 Joined: 7-June 15 From: Calgary Alberta Member No.: 18,814 Region Association: None |
Been working steadly on fixing my 1974 1.8L.
New injectors,plugs,Petronic point replacemnt.etc. Driving to the store when all of a sudden something happened. Car felt like it had dropped 1 of the cylinders. Car does not rev at all,made it home and parked it. Diid a compression test (cold),110 110 100 90. Not happy with 90 on cylinder 1 but felt at least like motor should still be running. Where do I go next.???? I have a dual vacuum line throttle body,and a single vacum on my for sure non stock distributor that had a 4500 RPm rev limiter. (Distribitor mark for cylinder 1 is 180 degrees out.) Like I said I put on a pertronic 1847 and a petronic blaster coil and 8MM wires. I am thinking its a spark think,but really dont know what to do at this point. I have ordered a Mallory Unilite distribitor(4554101),but wont install it till I figure this out. Hoping for some help from you guys. Thanks Grant. |
catsltd |
Aug 30 2015, 08:23 AM
The spark plug wires were a problem,but 5 minutes later the miss had returned.
But this is the real problem. The injector plug didnt look right,so I cut it and took a look. Its pretty easy to see what happens every time I plug it into my injector. If it was not for the suggestions I received,especially pulling a plug and seeing if it changes the way it runs. I dont think I would have ever found it. I am waiting for my new injector plugs. If the cord is held straight the connector looks normal,but as soon as you push on it or bend it,she disappears. |
Lo-Fi Version | Time is now: 6th June 2024 - 09:35 AM |
