Spark Plug Wires, For NGK BP5ES Plugs |
Alphaogre |
Aug 30 2015, 04:39 PM
Member Group: Members Posts: 460 Joined: 28-May 12 From: San Diego Member No.: 14,487 Region Association: Southern California |
Two things I noticed when changing my plugs to NGK Spark Plugs.
1) I noticed that when I went to put on the spark plug wires on to my new NGK pugs, the head of the plug is much larger then the old wire port? I also noticed the inner part of the spark plug is threaded, is there an adapter that screws in for smaller wire ports? 2) I also noticed while I had everything apart on of my spark plug wire ports was broken (the plastic end that connects to the spark plug)... (IMG:style_emoticons/default/headbang.gif) So now I have to buy a new kit anyway... - Do the NGK plugs have a certain head size I should look for in getting a new spark plug wire kit? Or just look for a "standard" wire kit and get the adapter? - Also, I am seeing wire kits anywhere from around $30 to $100. If you don't have a full MSD wire set up and built motor, would you notice the difference in spark plug wires between the median range wires or higher end wires? Thanks in advance... |
Dave_Darling |
Aug 31 2015, 08:43 AM
I'm not a big fan of the Bosch wires, either. But they do fit on 1.7s and 1.8s with a little convincing. They don't fit on the 2.0 motors, no matter how much you try to stretch them. If you get a set for the 912, that might fit on the 2.0 one? Not sure.
I use Beru wires for my 2.0. --DD |
Lo-Fi Version | Time is now: 6th June 2024 - 08:12 PM |
