rear sway bar cup install |
seanery |
Sep 16 2004, 09:26 AM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
man, sometimes it's the simplest things (IMG:style_emoticons/default/headbang.gif)
I can't get the ball cups into the droplinks for the rear sway bar. I tried the microwave for 20 seconds, warm but not pliable then I did it for 35 more seconds and cooked em...melty (IMG:style_emoticons/default/ohmy.gif) any been there done thats? |
HarveyH |
Sep 16 2004, 09:55 AM
Member Group: Members Posts: 450 Joined: 19-June 03 From: Downingtown, PA Member No.: 843 |
Microwave them in water to soften. Press into the drop links using a bench vise, C-clamp, or large (water pump) pliers. Remember that they enter the drop links from opposite directions. (IMG:style_emoticons/default/spank.gif) A little lube helps here.
When pressing onto the ball joints of the bar or the lower shock bolt don't use lube in the socket, it can form an air seal (IMG:style_emoticons/default/icon8.gif) preventing the socket from pressing onto the ball. Working on jack stands, I used water pump pliers to seat the drop links onto the balls. If you're working on a lift and have room to work under the car, I've been told you can use a long screwdriver or bar pivoted up in the wheel arch to lever them on. Harvey |
Lo-Fi Version | Time is now: 31st May 2024 - 10:19 PM |
