clapeza |
Member ![]() ![]() Group: Members Posts: 229 Joined: 7-February 11 From: South GA Member No.: 12,677 Region Association: South East States ![]() ![]() |
I'm in the process of getting rid of the single carb set-up and putting Djet back on my 1970 1.7L. I've rounded up the pieces from helpful members in this group, and I'm on the verge on putting pieces back in the car. None of the original FI components are in the car. Now that the heat index has dropped below 100 F, I might be able to get something done!
Here's what I've done so far: 1) Pulled the fuel tank. Boiled it out, Marine Clean'ed it, etched it with Metal Ready, and sealed it with the POR-15 tank sealer. 2) Got new stainless lines and fuel hoses from Racer Chris, but haven't installed them yet. 3) Cleaned, painted, and lubed most of the parts. 4) Got new gaskets and seals for the intake runners and injectors. What's the best order for putting the parts in place? FI brain first? When to install runners and injectors? When to re-plumb the fuel lines? Reinstall distributor? I'd hate to get deep into it and discover I have to take it all out just because I forgot to connect a vacuum line or ground wire under the plenum... Thanks! |
Bob L. |
Senior Member ![]() ![]() ![]() Group: Members Posts: 848 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region ![]() |
I would attach the injector ground wire to the engine case before the plenum, easier to get to. Also, don't attach the runners to the plenum until after the runners are in place but don't tighten the runners down until after the plenum is attached at the rubber hoses. That part took me a few tries.
Lo-Fi Version | Time is now: 1st July 2025 - 04:13 AM |
