| porschetub |
Sep 8 2015, 02:50 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,065 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I have the PMS filler pipe and it has the 1" breather pipe lateral on the side facing the rear of the car ,anyone run a K&N or similar breather filter in this location with good results?.
If so do you need to mount a rain shield over it ? ![]() |
| MJHanna |
Sep 8 2015, 07:23 AM
Does this 911 make my butt look big? ![]() ![]() ![]() Group: Members Posts: 806 Joined: 23-January 03 From: Lowry Crossing, Texas Member No.: 185 |
I run the hose into the trunk with a catch can. http://www.patrickmotorsports.com/part/bre...e-can-assembly/ I used to run the hose into the intake manifold like stock, but for some reason I was getting excess oil into the intake manifold which caused a smoke cloud every time I started the motor. The catch can solved that problem. Mine is homemade but works the same. |
porschetub Stock 914/6 oil tank,breather options? Sep 8 2015, 02:50 AM
Mark Henry
I have the PMS filler pipe and it has the 1... Sep 8 2015, 06:19 AM
naro914
I personally hate breather filters, they make a ... Sep 8 2015, 06:39 AM
Mark Henry I've always run a hose to the intake on the /4... Sep 8 2015, 06:50 AM
Steve I run the hose into the trunk with a catch can.
... Sep 8 2015, 07:17 AM
porschetub
I run the hose into the trunk with a catch can. ... Sep 8 2015, 05:02 PM
Mark Henry
:agree: [quote name='Steve' post='2234404' date='... Sep 8 2015, 09:31 AM
Steve
:agree: [quote name='Steve' post='2234404' date=... Sep 8 2015, 11:14 AM
SirAndy I used an old Gatorade bottle with a few holes dri... Sep 8 2015, 11:21 AM
porschetub
I used an old Gatorade bottle with a few holes dr... Sep 8 2015, 05:13 PM
gms I used to use an old Arizona ice tea bottle
Sep 8 2015, 05:28 PM
gms then I re-purposed a washer bottle
Sep 8 2015, 05:32 PM
t collins Less that 2000 miles on it and clean operation so ... Sep 8 2015, 06:41 PM
porschetub
Less that 2000 miles on it and clean operation so... Sep 8 2015, 08:02 PM
t collins
Less that 2000 miles on it and clean operation s... Sep 8 2015, 08:46 PM
mskala I really wanted to make something small and out of... Sep 8 2015, 06:57 PM
PanelBilly I had the fill neck modified with a threaded bung ... Sep 8 2015, 09:43 PM
porschetub
I had the fill neck modified with a threaded bung... Sep 9 2015, 01:42 AM
Maltese Falcon Tig welded aluminum catch can, breather tube to bo... Sep 9 2015, 12:25 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:00 PM |
