> Stock 914/6 oil tank,breather options?, K&N or similar?
porschetub
post Sep 8 2015, 02:50 AM
I have the PMS filler pipe and it has the 1" breather pipe lateral on the side facing the rear of the car ,anyone run a K&N or similar breather filter in this location with good results?.
If so do you need to mount a rain shield over it ?
Steve
post Sep 8 2015, 07:17 AM
I run the hose into the trunk with a catch can.
http://www.patrickmotorsports.com/part/bre...e-can-assembly/
I used to run the hose into the intake manifold like stock, but for some reason I was getting excess oil into the intake manifold which caused a smoke cloud every time I started the motor. This only occurred on cold starts. The catch can solved that problem.
porschetub
post Sep 8 2015, 05:02 PM
QUOTE(Steve @ Sep 9 2015, 01:17 AM) *
Thanks ,yea I thought that would be the case,the oil needs to be separated from the fumes and a catch can will do that,then I guess its just a case of taking the fumes away with vacuum from the intake after that?.
What sort of quantity of oil collects in the can on yours,is it much?.
So a catch can it is.....
porschetub   Stock 914/6 oil tank,breather options?   Sep 8 2015, 02:50 AM
Mark Henry   I have the PMS filler pipe and it has the 1...   Sep 8 2015, 06:19 AM
naro914   I personally hate breather filters, they make a ...   Sep 8 2015, 06:39 AM
Mark Henry   I've always run a hose to the intake on the /4...   Sep 8 2015, 06:50 AM
Steve   I run the hose into the trunk with a catch can. ...   Sep 8 2015, 07:17 AM
porschetub   I run the hose into the trunk with a catch can. ...   Sep 8 2015, 05:02 PM
MJHanna   :agree: I run the hose into the trunk with a catc...   Sep 8 2015, 07:23 AM
Mark Henry   :agree: [quote name='Steve' post='2234404' date='...   Sep 8 2015, 09:31 AM
Steve   :agree: [quote name='Steve' post='2234404' date=...   Sep 8 2015, 11:14 AM
SirAndy   I used an old Gatorade bottle with a few holes dri...   Sep 8 2015, 11:21 AM
porschetub   I used an old Gatorade bottle with a few holes dr...   Sep 8 2015, 05:13 PM
gms   I used to use an old Arizona ice tea bottle   Sep 8 2015, 05:28 PM
gms   then I re-purposed a washer bottle   Sep 8 2015, 05:32 PM
t collins   Less that 2000 miles on it and clean operation so ...   Sep 8 2015, 06:41 PM
porschetub   Less that 2000 miles on it and clean operation so...   Sep 8 2015, 08:02 PM
t collins   Less that 2000 miles on it and clean operation s...   Sep 8 2015, 08:46 PM
mskala   I really wanted to make something small and out of...   Sep 8 2015, 06:57 PM
PanelBilly   I had the fill neck modified with a threaded bung ...   Sep 8 2015, 09:43 PM
porschetub   I had the fill neck modified with a threaded bung...   Sep 9 2015, 01:42 AM
Maltese Falcon   Tig welded aluminum catch can, breather tube to bo...   Sep 9 2015, 12:25 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 06:05 PM
