| porschetub |
Sep 8 2015, 02:50 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,065 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I have the PMS filler pipe and it has the 1" breather pipe lateral on the side facing the rear of the car ,anyone run a K&N or similar breather filter in this location with good results?.
If so do you need to mount a rain shield over it ? ![]() |
| t collins |
Sep 8 2015, 06:41 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,270 Joined: 21-March 06 From: Virginia Member No.: 5,754 Region Association: None |
Less that 2000 miles on it and clean operation so far
| porschetub |
Sep 8 2015, 08:02 PM
| t collins |
Sep 8 2015, 08:46 PM
Less that 2000 miles on it and clean operation so far Any hassles doing valve clearances etc or do you just move it out of the way?. Looks great and most likely the way I'am heading. No clearance issues, I can pull #6 spark plug as is and it's easy to remove if every necessary. |
porschetub Stock 914/6 oil tank,breather options? Sep 8 2015, 02:50 AM
Mark Henry
I have the PMS filler pipe and it has the 1... Sep 8 2015, 06:19 AM
naro914
I personally hate breather filters, they make a ... Sep 8 2015, 06:39 AM
Mark Henry I've always run a hose to the intake on the /4... Sep 8 2015, 06:50 AM
Steve I run the hose into the trunk with a catch can.
... Sep 8 2015, 07:17 AM
porschetub
I run the hose into the trunk with a catch can. ... Sep 8 2015, 05:02 PM
MJHanna :agree:
I run the hose into the trunk with a catc... Sep 8 2015, 07:23 AM
Mark Henry
:agree: [quote name='Steve' post='2234404' date='... Sep 8 2015, 09:31 AM
Steve
:agree: [quote name='Steve' post='2234404' date=... Sep 8 2015, 11:14 AM
SirAndy I used an old Gatorade bottle with a few holes dri... Sep 8 2015, 11:21 AM
porschetub
I used an old Gatorade bottle with a few holes dr... Sep 8 2015, 05:13 PM
gms I used to use an old Arizona ice tea bottle
Sep 8 2015, 05:28 PM
gms then I re-purposed a washer bottle
Sep 8 2015, 05:32 PM
mskala I really wanted to make something small and out of... Sep 8 2015, 06:57 PM
PanelBilly I had the fill neck modified with a threaded bung ... Sep 8 2015, 09:43 PM
porschetub
I had the fill neck modified with a threaded bung... Sep 9 2015, 01:42 AM
Maltese Falcon Tig welded aluminum catch can, breather tube to bo... Sep 9 2015, 12:25 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:59 PM |
