Best 914 cover |
Best 914 cover |
last337 |
Sep 9 2015, 03:26 PM
Member Group: Members Posts: 421 Joined: 4-December 12 From: New Orleans Member No.: 15,221 Region Association: None |
I have finally moved the 914 from my shop to in front of the house now that I am finally able to drive it again. I am hoping that now that it is closer I will get to all those small things I wanted to fix when I have free time at home. Unfortunately I dont have a driveway and it is sitting out on the street. I have an umbrella cover on order from Perry for when I am out and about but I would like a nice full size cover for in front of the house. What do you guys recommend that will keep the rain off but not trap moisture inside either?
Chris Pincetich |
Sep 9 2015, 04:42 PM
B-) Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
The Coverking cover that Pelican sells is awesome, but expensive. Custom fit for a 914. Mine is now "worn out" after 5 years. It has some pin-holes in it that allow water in, but it was once totally waterproof.
For winter I put the Coverking on, then a waterproof tarp from the hardware store, then a cheap generic car cover on top and buckle that. The cheap cover keeps the sun exposure off of the expensive Coverking. The tarp is because the Coverking is no longer as waterproof as it once was. The Coverking works great now as a general sun and dust cover, but for the winter it is always the tarp sandwich! (IMG:style_emoticons/default/beerchug.gif) One benefit of the "three-ply" cover strategy is that you'll almost always get the car wet when removing a wet cover. With the 3-ply, I take the cheap cover and roll it off inside the tarp, and the Coverking, which is basically dry, stops any water from getting into or on the car. (IMG:style_emoticons/default/biggrin.gif) |
last337 |
Sep 9 2015, 05:11 PM
The Coverking cover that Pelican sells is awesome, but expensive. Custom fit for a 914. Mine is now "worn out" after 5 years. It has some pin-holes in it that allow water in, but it was once totally waterproof. For winter I put the Coverking on, then a waterproof tarp from the hardware store, then a cheap generic car cover on top and buckle that. The cheap cover keeps the sun exposure off of the expensive Coverking. The tarp is because the Coverking is no longer as waterproof as it once was. The Coverking works great now as a general sun and dust cover, but for the winter it is always the tarp sandwich! (IMG:style_emoticons/default/beerchug.gif) One benefit of the "three-ply" cover strategy is that you'll almost always get the car wet when removing a wet cover. With the 3-ply, I take the cheap cover and roll it off inside the tarp, and the Coverking, which is basically dry, stops any water from getting into or on the car. (IMG:style_emoticons/default/biggrin.gif) Thanks for the suggestion! Which Coverking cover did you get? They have several models on there now. |
Lo-Fi Version | Time is now: 2nd June 2024 - 08:39 PM |
