Parts required to put iginition on the dash, ...ala the /6 |
boxsterfan |
Sep 9 2015, 05:47 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
What are all of the parts required to get the ignition switch on the dash? I am imagining /6 steering columns are hard to come by or rather pricey? Other alternatives?
Seems like the big one if the steering column area so that you can have the steering wheel lock. Also, seems like something would have to be done to cleanup the original ignition switch location on the column. |
naro914 |
Sep 10 2015, 01:19 PM
Losing my mind... Group: Members Posts: 2,476 Joined: 26-May 06 From: Charlotte, NC Member No.: 6,073 Region Association: South East States |
I just got a 911 ignition switch, drilled a hole (though I think I just used one that was there), took out the column switch and welded it shut. It uses the stock 914 everything else (switches and all) I don't have a steering column lock, and its the 'wrong' ignition in the dash, but thats OK with me....I was never looking for authenticity...
boxsterfan |
Sep 10 2015, 04:29 PM
I just got a 911 ignition switch, drilled a hole (though I think I just used one that was there), took out the column switch and welded it shut. It uses the stock 914 everything else (switches and all) I don't have a steering column lock, and its the 'wrong' ignition in the dash, but thats OK with me....I was never looking for authenticity... This is a pretty good idea also. I could live without a steering lock (although parking on steep hills would leave you open to some risk). Perhaps a manual lock mechanism could be worked out. And it it is a 911 iginition switch, well...then it is a Porsche part!! :-) |
Lo-Fi Version | Time is now: 16th June 2024 - 07:12 AM |
