Consensus,On best way to convert a 914, Best way to do a Subie 914 conversion |
flmont |
Sep 9 2015, 05:59 PM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
Ok,..with all the MAJOR experienced people on this form,..and these conversions being accomplished for years now,..is there a BEST way to do a SUBIE conversion or a most popular,.. or easiest way to convert.(regardless of engine choice).
Meaning,..best radiator to use,due to size,..or run lines under car, or thru the longs,.best hose to use,..or fittings,..engine cradel's ,..which fuel pumps work well,..what's the best way to strip down a harness,..or have it done.. Etc I know a lot of this is personal preference,.or used what's available,..I cant belive someone didn't write a book of guidelines on this,...Its seems very popular,...a few years ago I would have never even considerd doing this,..and NOW,..I cant wait to get started,..!!!!! |
flmont |
Sep 10 2015, 04:58 PM
Yea,..WOW..the Brittan site is a lot of info,..Thanks...DBCooper,...I want to keep as much 914 as I can...just upgrade ,..engine,..rebuild the 901 to handel the EG33...That's the goal at this time,.. we shall see how it goes ...Thanks Frank
PS,..is it best to run lines thru the longs..??? |
mgp4591 |
Sep 10 2015, 08:58 PM
914 Guru Group: Members Posts: 5,383 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
Yea,..WOW..the Brittan site is a lot of info,..Thanks...DBCooper,...I want to keep as much 914 as I can...just upgrade ,..engine,..rebuild the 901 to handel the EG33...That's the goal at this time,.. we shall see how it goes ...Thanks Frank PS,..is it best to run lines thru the longs..??? I'd use a Subie transmission- you'll spend as much if not more buying the adapter and rebuilding the 901 as you would to source a good Subie 5 speed and buying the shift mechanism, cables and such. Plus you'll have a great match for the driveline and parts you can buy right off the parts counter at Subaru. You'll have to have custom axles but they're readily available and you don't want to use stock axles with an EG33 anyway- too much power for the stock stuff... (IMG:style_emoticons/default/shades.gif) |
Lo-Fi Version | Time is now: 12th June 2024 - 02:12 AM |
