Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,542 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California ![]() |
hey guys,
i have a 2.0 euro piston'd, weber 44'd engine with a Moderate - big cam. so much so that stock 44's work very well (dead on jetting - off the shelf) IIRC i was told that the advance from my 050 dizzy wasnt optimum for my cam. my engine wil cruise all day long like stock but is a Beast 2500 to 6000. but mildly hesitate when it comes off idle circuit to mains when you jump on it. (explained to me that its the difference in vacuum when the powerband comes on, kinda fakes out the webers) im contemplating a mallory dizzy.... what should the static and full advance timing be set to? (mallory is adjustable) also, the unilite optical pickup w/o vac advance - will it still generate a useable tach signal? thanks dudes, Aaron |
machina |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 ![]() ![]() |
From RAT
"dizzy model#4554101 The TIV default (safe) settings should be 28-32 degrees full timing (unless your engine is a low CR misconfigured beast, then it may want 40 degrees) and set up initial at 11 degrees. Install a pair of Grey springs, and go from there" |
Lo-Fi Version | Time is now: 21st August 2025 - 04:13 AM |
