> Which cams for my carbed 2.7 /6 build- E or S?
tornik550
post Sep 12 2015, 09:06 AM
Which cams should I use for my /6. I have two different cam sets. I have E and S sets. I do not want to buy new cams. My car is simply for fun on the road. This is my general setup that I am building.
2.7l
70.4mm crank
Stock 2.7l heads
9.5:1 JE 90mm pistons
Dual zenith carbs.
Peashooter
post Sep 12 2015, 02:06 PM
Do you have the S heads with the 35mm ports or the standard heads with I think 32mm ports? If the std. heads, I'd go with the E cams for sure. Better low end and mid range. Unless you are going to track the car a lot, the E cams are a better fit for the street.
- Lo-Fi Version Time is now: 15th July 2025 - 09:56 AM
