tornik550 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None ![]() |
Which cams should I use for my /6. I have two different cam sets. I have E and S sets. I do not want to buy new cams. My car is simply for fun on the road. This is my general setup that I am building.
2.7l 70.4mm crank Stock 2.7l heads 9.5:1 JE 90mm pistons Dual zenith carbs. |
GeorgeRud |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest ![]() |
When Supertec rebuilt my 2.7 with a RS piston/cylinder set, Henry put in his S cams, and the results are amazing. Plenty of torque throughout the rev range, but it's a rocket ship when it's above 4000 rpm. 199hp at the rear wheels using Weber carbs and factory heat exchangers. I think the larger displacement makes up for any low end torque issues with the hotter cams.
Lo-Fi Version | Time is now: 15th July 2025 - 10:45 AM |
