| Ansbacher |
Sep 14 2015, 03:18 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 689 Joined: 4-July 14 From: Tampa Bay, Florida Member No.: 17,589 |
I have been reading posts and info about replacing the stock oil temp gauge with a new VDO replacement that actually reads in degree numbers, but am more confused than when I started. Does anyone know what VDO gauge to buy and what is the matching temp sensor to use with it? Specific part numbers and sourcing would be greatly appreciated. Also how straight forward is this conversion?
Car is a '74 2.0L. I would be replacing the center console gauge. Thanks all, Ansbacher |
| Dave_Darling |
Sep 14 2015, 04:33 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,365 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
First, there is no direct replacement with numbers available. That's because the center console gauges are a slightly different diameter than the VDO gauges that are common today. To fit a modern gauge in the old console, you will probably need an adaptor ring (bottom of this page), or at least a good wrapping of black electrical tape.
Second, there are a number of aftermarket gauges that will work in different circumstances. The important thing is that you get a gauge and sender that are set up for each other. Looks like Pelican doesn't have anything listed, which is too bad. But the sender and gauge need to have the same temperature range, the gauge has to have the right diameter (or close enough), and the sender has to thread into the bung in the engine. --DD |
Ansbacher Oil Temp Gauge Replacement Questions Sep 14 2015, 03:18 PM
dangerranger01 This page has tons of info on this thing. Bottom l... Sep 14 2015, 04:40 PM
SKL1 I sent my OEM temp gauge to North Hollywood Speedo... Sep 14 2015, 05:18 PM
Ansbacher Thanks a million everyone for the great info and p... Sep 14 2015, 06:04 PM
Montreal914 I would still do a boiling water test to make sure... Sep 14 2015, 07:45 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd November 2026 - 01:30 PM |
