> Drops to idle fast and then chokes
p914
post Sep 16 2004, 01:45 PM
I have the DJet system on my 75 2.0.
When the engine is all warmed up, and i come to a stop and the engine drops to idle, it sputters and chokes. Then if it continues to run it will slowly ramp back up to proper idle. Sounds like it just drops down to idle too fast for the old DJet.
The engine runs like a top except for when it is warmed up and that little idle problem kicks in.
Is there anything that can slow down the revs so it doesn;t just drop down to idle other than using the gas pedal? I took off all the air pump stuf years ago, so that system is not there anymore.
p914
post Sep 17 2004, 12:48 PM
Along with the ecu adj. you may need to adjust the idle screw on the intake.
p914   Drops to idle fast and then chokes   Sep 16 2004, 01:45 PM
2-OH!   I have the same problem...Been asking, but no one ...   Sep 17 2004, 07:39 AM
michelko   hi, try this link http://members.rennlist.com/pban...   Sep 17 2004, 07:45 AM
2-OH!   Thanks michelko, I'll give it a try... 2-OH...   Sep 17 2004, 07:50 AM
RustyWa   Won't it do that if the car is lean? Maybe tr...   Sep 17 2004, 08:10 AM
tod914   Maybe test your head temp. sensor???   Sep 17 2004, 08:34 AM
p914   Mine doesn't hunt as the mixture is good. It w...   Sep 17 2004, 08:36 AM
2-OH!   Tod: New head sensor...Put one in during the engi...   Sep 17 2004, 11:17 AM
p914   Along with the ecu adj. you may need to adjust th...   Sep 17 2004, 12:48 PM
p914   It needed a valve adjustment. Didn't put more...   Oct 7 2004, 11:43 AM
Rhodes71/914
  Oct 7 2004, 11:53 AM
p914   Seems like adjustments would last up to 6k miles.....   Oct 7 2004, 12:14 PM
SirAndy     Oct 7 2004, 12:18 PM
Rhodes71/914
  Oct 7 2004, 12:34 PM
p914   I think the decel valve was taken out a year or so...   Oct 7 2004, 03:33 PM
- Lo-Fi Version Time is now: 10th March 2026 - 09:31 PM
