Finding a distributor, Can anyone point me to a replacement part? |
porschefile2010 |
Sep 14 2015, 01:19 PM
Member Group: Members Posts: 228 Joined: 26-May 11 From: Whangaparaoa, New Zealand Member No.: 13,118 Region Association: Australia and New Zealand |
1975 2.0 After nearly $NZ900 spent tracking a problem with the car dropping two cylinders ( including new trigger points, coil and more ) we have finally worked out that the distributor is the problem. Although the car would start and run for a few minutes it would suddenly start flooding 2/4.
AA don't have a distributor in stock and Pelican's site doesn't seem to have my part no 022 905 205F. Does anyone on the board know where I might find a replacement at a sensible cost. Thanks once again. |
914Mels |
Sep 15 2015, 10:00 AM
Member Group: Members Posts: 357 Joined: 20-June 11 From: Santee Member No.: 13,221 Region Association: Southern California |
I've never seen a distributor cause a flooding problem. If you have bad trigger points you pretty much lose the injector signal and no gas flows. If your are getting a couple cylinders going super rich like it sounds like you are saying, it is probably the ECM drivers gone bad. See if you can find a loaner ECM to put in before you go for a distributor.
Lo-Fi Version | Time is now: 2nd June 2024 - 06:23 PM |
