The plenum, What's under there? |
Porschef |
Sep 15 2015, 07:01 PM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
Drove the car to work today and it's running very well. When I got home I wanted to check a couple things. Don't know why I did it, but the last thing was to spray some carb cleaner around to check for vacuum leaks. When I sprayed some under the plenum, she almost stalled out. Sumbitch! I thought I'd found all the vacuum leaks.
Question is, what's under the plenum that might allow it to suck air? Could there be a crack? Great, gives me another excuse to wrench on the car. Also should allow me to lean it out a bit more at the AFM. It's L-jet, btw. Any ideas? |
Porschef |
Sep 17 2015, 05:50 PM
Looks fine. I don't know what was making it almost want to stall with carb cleaner but I'll go through everything again (IMG:style_emoticons/default/mad.gif)
At least I can clean up the compartment a bit. (IMG:style_emoticons/default/dry.gif) |
Lo-Fi Version | Time is now: 11th June 2024 - 03:25 PM |
