ThinAir |
Best friends ![]() ![]() ![]() ![]() Group: Members Posts: 2,569 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region ![]() ![]() |
The steering shaft has a "grooved ball bearing" on it (that's what Haynes calls it). It's located "inside" the dash area, behind the steering column switch assembly so you don't normally see it. On every 914 I've ever driven, this bearing is really noisy and sounds like it's full of sand. Since I've got the whole steering assembly in pieces I figured it was a good time to lubricate this bearing to quiet it, but what do I use to lubricate it?
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,542 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California ![]() |
QUOTE in pieces then whats the big deal about using a finger in wheel bearing grease? (IMG:style_emoticons/default/blink.gif) , did you pull the column housing etc? |
Lo-Fi Version | Time is now: 5th July 2025 - 06:20 PM |
