To repair or not |
To repair or not |
mckeedad6 |
Sep 18 2015, 10:46 AM
Newbie Group: Members Posts: 40 Joined: 15-September 15 From: Imlay City, MI Member No.: 19,161 Region Association: Upper MidWest |
Ok Guys. I have decided to sell my uncles 74 914. Question is how much more would it be worth if I replaced the rear trunk floor. Would it add that much extra value or should I leave it as is for next owner to deal with. This is the only bad rust on the car all other trouble spots are clean and solid. thanks for your help.
Attached thumbnail(s) |
scotty b |
Sep 18 2015, 11:39 AM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
a proper repair is going to cost more than you will gain by doing it. A cover up will turn prospective buyers off for god. If you want to try for a couple extra bucks, cut it all out and get it prepped for a new panel. I for one would rather see it all cut out and cleaned ready for repair, than the swiss cheese it currently is. Otherwise leave it be and take what you can get.
mckeedad6 |
Sep 18 2015, 11:42 AM
a proper repair is going to cost more than you will gain by doing it. A cover up will turn prospective buyers off for god. If you want to try for a couple extra bucks, cut it all out and get it prepped for a new panel. I for one would rather see it all cut out and cleaned ready for repair, than the swiss cheese it currently is. Otherwise leave it be and take what you can get. Thanks. Any idea on the negative effect it should have on price? Just curious. |
scotty b |
Sep 18 2015, 11:47 AM
a proper repair is going to cost more than you will gain by doing it. A cover up will turn prospective buyers off for god. If you want to try for a couple extra bucks, cut it all out and get it prepped for a new panel. I for one would rather see it all cut out and cleaned ready for repair, than the swiss cheese it currently is. Otherwise leave it be and take what you can get. Thanks. Any idea on the negative effect it should have on price? Just curious. a proper trunk repair from a good shop is going to run 1500-2000.00 parts and labor. That is all depending on the shops rate, how perfect you want it done, and what may lie under the known issue. I would suspect someone looking to do it themselves might want to knock 500.00 +or- off |
Lo-Fi Version | Time is now: 2nd June 2024 - 10:22 AM |
