The plenum, What's under there? |
Porschef |
Sep 15 2015, 07:01 PM
How you doin' Group: Members Posts: 2,166 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
Drove the car to work today and it's running very well. When I got home I wanted to check a couple things. Don't know why I did it, but the last thing was to spray some carb cleaner around to check for vacuum leaks. When I sprayed some under the plenum, she almost stalled out. Sumbitch! I thought I'd found all the vacuum leaks.
Question is, what's under the plenum that might allow it to suck air? Could there be a crack? Great, gives me another excuse to wrench on the car. Also should allow me to lean it out a bit more at the AFM. It's L-jet, btw. Any ideas? |
Porschef |
Sep 18 2015, 02:00 PM
Andy, it's a 2056 with Ljet. Should that matter?
Trough tubes, are you referring to the runner connections? Rob, I'm pretty sure the cable isn't yanking on the plenum, but I'll check after reassembly. Thanks gentlemen |
Lo-Fi Version | Time is now: 11th June 2024 - 07:43 PM |
