Engine tin, Air duct floor interference with shift rod |
jsaum |
Sep 18 2015, 10:11 AM
Senior Member Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None |
I'm having an issue with the drivers side engine tin that covers the shift rod on my side shifter trans. After installing the bottom drivers side engine tin I found that it was touching the shift rod and I couldn't shift into reverse or first gear. I have a 1.8 with SS exhaust, since the shift rod is locked into place with the conical screws the only adjustment place I see is at the shift lever. I'm also using a short shifter. Has anyone run into this problem before? How close does the engine tin normally come to the shift rod?
Thanks, Jsaum |
ndfrigi |
Sep 20 2015, 08:05 PM
Advanced Member Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
jsaum |
Sep 20 2015, 08:14 PM
If you remove that tin and your shifting is doing fine, just remove that or maybe find a replacement for that tin. I believed that is basically part of the heater tins. Currently, I don't have that tin installed but my car is running well. Thanks, yes I did take it off. Now I'm looking for one just because I like to keep things as stock as possible. I'll probably never tell any difference in the way the cars runs. |
Lo-Fi Version | Time is now: 2nd June 2024 - 08:20 PM |
