Hi beams, How do you turn them on ? |
913B |
Sep 20 2015, 11:21 AM
Senior Member Group: Members Posts: 847 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
I tried pulling the left stalk towards me, but don't get any click or activation of the high beams at all, low beams are fine. Its a 71 BTW.
Any thoughts and things to check ? Thanks Ted |
Dave_Darling |
Sep 21 2015, 09:10 AM
You can check the switch and some of the wiring by checking to see if pin "S" on the high/low relay socket gets grounded when you pull the stalk back.
You can check the relay by unplugging it, hooking +12V to "56", then momentarily grounding "S". If the relay doesn't click, it's bad. It may be possible to open the relay up, clean it up, and re-test. --DD |
Lo-Fi Version | Time is now: 13th June 2024 - 06:07 AM |
