Alternative Ventalation, Venting on venting |
forrestkhaag |
Sep 21 2015, 07:24 PM
Senior Member Group: Members Posts: 935 Joined: 21-April 14 From: Scottsdale, Arizona Member No.: 17,273 Region Association: Southwest Region |
Alternative Ventilation
Has anyone perfected a simple interior ventilation system once the hvac is blanked off and deleted in an early 914? My goal is to have a two-sided control total mechanical system to shove some fresh air into the cabin when the windows are up / one side or the other or both / not to the windshield but to the lower cabin only. In SoCal, we have no humidity, no rain, no inclement weather, not one single bug, no latent dust (unless behind a 6…, and no particulate allergens or pollen, so I am thinking that the system will be an add-on to my tow bar hitch receiver tubes subtly located thru the front bumper and in to the front trunk bay… but…. from there, things get difficult due to this big bulbous thing called a fuel tank….. I know from many removals and insertions of the tank that there is no room for two flexible tubes to make their way thru the tank cavity unless we agree to go electric. So, maybe someone has another route for two individually mechanically controlled vent tubes to the front cabin. Of course, the Germans used the cowl vent to drain rain and to power up ventilation to the cabin and windshield. I am looking for a simple alternative.. Any suggestions are appreciated. |
914_teener |
Sep 21 2015, 07:35 PM
914 Guru Group: Members Posts: 5,204 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
I don.t get why the stock fresh air intake won.t work?
It is simple but a PITA to take apart and reinstall. |
76-914 |
Sep 22 2015, 06:35 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I don.t get why the stock fresh air intake won.t work? It is simple but a PITA to take apart and reinstall. I fart with more force than that anemic OEM vent system puts out. (IMG:style_emoticons/default/dry.gif) Another BIG + when one does a water cooled conversion and AC (IMG:style_emoticons/default/biggrin.gif) |
914_teener |
Sep 22 2015, 07:22 PM
I don.t get why the stock fresh air intake won.t work? It is simple but a PITA to take apart and reinstall. I fart with more force than that anemic OEM vent system puts out. (IMG:style_emoticons/default/dry.gif) Another BIG + when one does a water cooled conversion and AC (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/flag.gif) Not sayin use the little fart fan that isthe OEM.....use the same entry and exit points and higher output fans. I have no comment about the volocity of your farts Kent.... |
Lo-Fi Version | Time is now: 2nd June 2024 - 03:38 AM |
